Suspension Travel in Bump
liam.mccaffrey - 26/3/11 at 09:00 PM
What sort of suspension travel are you folks seeing in bump?
MikeCapon - 28/3/11 at 09:24 AM
Hi Liam,
As no-one else has replied here's my contribution.
The bump movement is reliant on the total travel available. For a seven type car the total travel will be around 100mm and bump will be 60-70% of that, leaving 30-40% as droop.
HTH
Mike
Frosty - 28/3/11 at 02:24 PM
I think most 7 setups are aimed at around 3 inches of total damper movement, allowing 2 inches of bump, and 1 inch of rebound.
Put another way, the weight of the car compresses the suspension around an inch, giving a further 2 inches of movement.
