Morning all
After some advise rebuilding a pair of sierra rear calipers today for use on my car. I have a new seal kit from bigg red and was wondering if you need
to put any oil on the seals before use/fitment and if so which oil. Many thanks
Sam
Under no circumstances use oil on any rubber brake part or any surface rubber or brake fluid makes contact with, this includes WD40 which contains
parrafin/gas oil type hydrocarbons.
To lubricate brake parts use Castrol Girling Red Rubber Grease ---- do an ebay search on "Red Rubber Grease"
[Edited on 17/5/11 by britishtrident]
Originally posted by britishtrident
Under no circumstances use oil on any rubber brake part or any surface rubber or brake fluid makes contact with, this includes WD40 which contains parrafin/gas oil type hydrocarbons.
Worth getting a big tub , Rubber grease is ace stuff for other things -- very water proof excellent at preventing alloy wheels seizing on to hubs or track rod ends seizing on track rods much better than Coppaslip.
The other trick when re-using O rings exposed to petrol is wash them in warm soapy (ie hand soap) water and allow to dry.
