Hispec brake lines
ChrisL - 22/5/11 at 06:49 PM
I'm about to order some new brake hoses to go with my new Hispec callipers, however I've not got a clue what things are called!
So 2 questions, what are the correct fitting hose ends for hispec callipers, pic here:
And the other end, it's actually the same as the Sierra brake calliper fitting, pics here: Description
& Description
TIA
Chris
omega0684 - 22/5/11 at 06:58 PM
m10 x 1.0 is the thread in the caliper (im assuming your using the sierra replacement caliper?)
SEE HERE
[Edited on 22/5/11 by omega0684]
Ben_Copeland - 22/5/11 at 07:18 PM
If one of the ends is shorter, it'll probably be the caliper one... the other end will be a bulkhead fitting, which needs a securing nut and a female connector...
mark chandler - 22/5/11 at 08:14 PM
The caliper will be an NTP fitting, although you can do what I did and use a copper washer and cut the end of the screw threads short so the as not to stick to far in or if you want an angled fitting use a banjo bolt.
From other threads best talking to russbott (search on username and send a U2U) about your requirements as he will make up the fittings to your exact needs at a good price.
Do not forget to measure with the wheels at full droop and full lock, this can easily add a few inches, to stop fouling you tighten with a twist.
Regards Mark
[Edited on 22/5/11 by mark chandler]
ChrisL - 22/5/11 at 09:01 PM
Cheers Mark,
U2U sent!
ChrisL - 24/5/11 at 09:24 PM
Big thanks to Russbost, who lived up to his reputation on this forum and patiently listened to my attempts to describe what I wanted, correctly deciphered and promptly sent out the correct hoses.
Also thanks go to Omega, Ben and Mark
Chris
[Edited on 24/5/11 by ChrisL]
