I have need of advice again.
I'm slowly doing up my Sprite, and am starting to look seriously at the front suspension. I'm changing to sierra uprights which have the
steering arm integral to the bottom of the upright, whilst the Sprite's are bolted on at the top.
Having had a close look at the uprights, there is a nice flat section at the top where it would be possible to weld a thick bit of steel to act as a
steering arm, possibly going as far over as the pinch bolt hole. I would then remove most/all of the current steering arm.
I can't think of a way of bolting a steering arm on where I need it, and I don't like the idea of using an extension piece to move the ball
joint upwards from the current steering arm as I'm worried about it not being stiff enough.
My question though, is would welding a piece of 10mm or so steel on cause any issues with the upright itself? I think they're cast steel, so the
welding itself should be fairly simple.
Originally posted by DIY Si
the welding itself should be fairly simple.
I think you'll find its totally the opposite. The heat you add to the casting ruins the grain and its likely to fracture. I think its probably an MOT failure as well unless you hide it.
To be sure I would get this bit welded by an expert.
Suspect it would be an instant MOT failure
I'd have serious reservations doing it, i'd be thinking of the consequence and possible outcome if it was to fail while driving.
Originally posted by phelpsa
I'm pretty sure they're forged not cast and therefore no real problems.
SG cast iron as are most parts on Fords that are forgings on other makes.
Way to test for cast Iron is attack it with an angle grinder, if produces lots of black dust it is cast iron.
They are, as confirmed by Coozer a while back, at the Ford plant in Belguim, cast.
"The uprights are cast from Spheroidal graphite cast iron. DIN EN 1563"
You should NOT be welding to these.
Hmm - The uprights on my Silva Riot as supplied by Jeremy are ford items and they are welded. Silva have an enviable engineering heritage and I would
be surprised if they did anything remotely dodgy.
Might be worth a bit more investigation.
Cheers!
to start with, i would not be welding them.
however that said, its quite ok to fabircate your own welded uprights? whats the deal with that at iva/mot etc?
Originally posted by v8kid
Hmm - The uprights on my Silva Riot as supplied by Jeremy are ford items and they are welded. Silva have an enviable engineering heritage and I would be surprised if they did anything remotely dodgy.
Cheers!
http://www.rallydesign.co.uk/catalog/product_info.php?cPath=1375_1594_1595&products_id=13605
you can bolt them on however you like
Indeed, but at £400 for uprights, hubs with the wrong PCD and all the bits they're not very locost!
Ha! checked the uprights and they are specified as Capri ones could that be the difference?
I think there is a bit of confusion regarding manufacturing process, Ford cast a lot of parts in SG Cast iron which is different manufacturing
process and material from drop forging steel, however welding steering parts made from either is a definite o-go.
SG cast iron is a very high strtength cast iron Ford pioneered the use of it for components such as crankshafts and connecting rods.
So either way then, I'll have to either bolt something to the top of the upright, extend the mushroom some how, or use a spacer on the existing steering arm?
Interesting that modifying the suspension components would invalidate the MOT, but making your own doesn't?!
That was part of my thinking. I could design and make my own welded uprights, but welding something to a steel upright would cause issues. Since mine aren't steel for me it's irrelevant, but an oddity all the same.
Yep, they are drop forged and therefore the grain structure is critical. Welding them will end in disaster![]()
Not really, a fabricated upright would have to be made from a material that is suitable for welding. Welding something as critical as a steering arm onto a cast component is obviously a very poor idea.
