Steering UJ on Page 70 of "The book"
Matthew_1 - 22/7/04 at 10:43 PM
Does anyone know what rack the lower UJ is from on page 70. The one I have from a Sierra rack has a great fat rubber joint. I'm after a narrower bit.
DavidM - 23/7/04 at 12:27 AM
I think that is also Sierra. Some had a rubber coupling and some a UJ. I could only find rubber ones when looking for mine.
There have been previous posts regarding steering UJ's which may give more info.
JAG - 23/7/04 at 08:00 AM
Depends which version of the book!
My copy suggests using an Allegro steering column - perhaps the UJ is from that. The later book probably has a Sierra column because of the crumple zone requirement in the SVA test.
Steve Hnz - 23/7/04 at 10:41 AM
An earlier post on this topic gave it as an Allegro lower joint, I suspect that other BL cars, ie Princess, Marina might have had similar.
craig1410 - 23/7/04 at 11:42 AM
Hi,
You can buy one of these joints from Rally Design for about £18 IIRC. They are called "Group 4 Steering Coupling" in the catalogue and have splines to match the Sierra/Escort racks at both ends. There is also another company who can supply the joint AND a little piece of steel bar with the splines already machined. Check posts on this forum over the last 3 months or so. I'll check too in a moment and post a link if I can find it.
Found it:
http://www.locostbuilders.co.uk/viewthread.php?tid=14146&page=1
Cambridge Motorsport it is.
Craig.
[Edited on 23/7/2004 by craig1410]
Matthew_1 - 23/7/04 at 11:58 AM
Cheers.
PS is it just my eyes, or is the rally design website totally illegible ?
phelpsa - 23/7/04 at 12:17 PM
I agree, it's a scan of their brochure (laziness )
Adam
[Edited on 23/7/04 by phelpsa]
craig1410 - 23/7/04 at 05:02 PM
Yes but they will give you a free catalogue if you ask them. It is actually a magazine (C&CC IIRC) but it has a large Raldes section. Despite their very poor website I have always found them to be a useful company so don't let that put you off...
Craig.
James - 23/7/04 at 06:07 PM
It's your eyes mate! Did your mother not warn you that too much http://www.flashyourrack.com ruins your eyesight?
James
[Edited on 23/7/04 by James]
ernie - 23/7/04 at 07:02 PM
I used lower u/j from mk1/2 fiesta whitch fits escort rack and you can weld anything the other end
