Super fast delivery of Wilwood midilite 4 piston brake set up complete kit with 285mm x 24mm discs, pads & brackets all looked good until it came
to fitting them.
That's why I use rally design, if something goes wrong they put it right, Burton's on the other hand would probably have charged you to return them and that's if they could be arsed to answer the phone!
I had a fair bit of 'fettling' when installing the Powerlite (Cortina) kit on a Westfield (..and yes, it had Cortina uprights, etc..). I had
an enormous amount of 'grief' fitting a Powerlite (Capri) kit on a R1oT... however, with a good few hours, a pint (or two) of real ale, the
result was very good (even sober).
I'm different, I expect some grief.
One thing though, Rally Design have always been helpful, resolution of problems is something that concerns them.
HiSpec....
I've just fitted the Wilwoods I bought from Carl on here, straight on, no fiddling, probably the simplest job I've ever done on the car
No Fare!!![]()
I was expecting it to be a snip of a job.
Shuks, just my luck!
Shop at LCB, you know you're dealing with good people who know their stuff (and we didn't get looted)
quote:.
Says the man who left his garage door open, with the lights on, on the worst week of looting we've ever had![]()
We're you trying to tempt a Norwich riot?![]()
Errm ummm is it safe to mention the R word or will it be 4 years banged up
