Does anyone know if a 2 wheel drive saphire cosworth sump will fit onto a 2.0 pinto. somebody said to me that they are the same 205 block is this
right.
rs alloy sump fits im not sure if the saphire one is the same i think so.
never done it but the block is certainly the same, not sure on the oil pump (pickup pipe is attached to it) but I would guess it is also the same?
Thanks guys
yes it will fit
sorry for the hijack
What thickness plate have people used to reconstruct the sump when chopping the 2.0 pinto one?
90% sure I went with 18 gauge. Don't think I went as thick as 16.
HTH,
James
is that about 1.6mm ish?
16 gauge is 1.6mm
18 gauge is 1.2mm
I just went with a thickness similar to what was there already so as to make it easy to weld.
Atb,
James
