Can't get the little varmints out, any ideas?
Big hammer!
I use a ball joint splitter to press them out.
Do you mean removing a stud from the hub (separate stud and wheel nut )or are you trying
to get a wheel off that is held on with modern type threaded studs/bolts ?
Stud from hub and the big hammer did work
