hi, can anyone advise best english diff ratios for road going car with pinto engine.Tyres 13 inch 60 profile.How do i check my exist diff ratio and can any recommend supplier or rebuilder of complete diff assy. thanks
Mine is a 3.75 but first gear is almost redundant so would have preferred a 3.44.
What gearbox?
The English axle had a rocket box or similar 4 speed which usually had a longer 1st than the type 9 5 speed.
It would be well worth looking at a gear ratio, tyre size spread sheet, you'll then get a good idea what speed in gear you will get.
Don't think English axles come in 3.44, mine's a 3.54. Coupled to a 4 speed box, it seems about right for the road.
