do you really need wider wheels at the rear if running wider tyres?
for instance could i run 13x6 front and rear, 185 fronts and a 205 rear width? to aid with grip or do i really want to be running 7 or 8 at the rear
for that?
Have a peek here
http://www.alloywheels.com/tyrecalc.asp
Handling is generally best with the tyre at the narrow end of the suitable fitments range for the wheel's width.
A wide tyre on a relatively narrow rim rolls/squirms about a more.
205's on 6" rims for the rear whilst within the acceptable range are a bit to big, 7" would-be best
ive gone 7" wheels with 205 rears and 185 fronts
if thats any use to you
