I'd like to keep salt, grit and water out of the 4 rod end bearings on my rear suspension. Something like a steering rack bellows would do this a
treat, stick a bit of oil in, tighten up with tiewraps.
Is there anything out there I should know about?
I want fit & forget, minimal maintenance.
Bob C
You get covers that are made to do that very job>
from?????????
http://www.charit4.org.uk/rotaprecision/motorsport.htm
some people just need spoon feeding
atb
nursie
some people cant help taking the wee either lol
Thought nursie was a weekend only activity Steve?
Ta Steve - nearly what I'm looking for.... (those on the site would require re-make of wishbones...)(spits dummy out......)
Bob C
colm....
Its Friday.....
nearly there!
Bob
did you see both types? the washer ones and the bootee types?
atb
steve
Yeah mate, but me clevis is a close fit on the ball - I need sommat to go right round the lot! - more of a bag than a boot; I think a wee steering
bellows is the answer! TTFN
Bob
Those Sealit washers are absolutely useless. Fine dirt does get past them and then it is captive and grinds away at the bearing.
What you are talking about are genuine rod end boots that encompass the whole end, but do not include washers. Rose (as in Rose joints) are the only
manufacturer I know of who supply them. They are not very popular because they do not work either. If you use Teflon lined rod ends they are self
sealing and the Teflon acts like a wiper on the ball. Nothing is totally grit proof but the Teflon lined ones will outlast any metal to metal joints
in a dirty situation. The bronze lined reo ends require oil/grease to lubricate them which attracts dirt and acts like grinding paste. Teflon lined
bearings should not be lubricated.
RESB and ABC sell the boots.
I have also tried filling the boots with silicon grease in the past and this seems to help.
John
Who Are those two companies ?
www.google.com gives the following:
http://www.resb.co.uk/
http://www.autosport-bearings.co.uk/
They are companies that sell bearings and ones that I have used for years.
John
