limited slip diff for drag raccing
metro6r4 - 20/10/11 at 07:34 PM
im after a limited slip diff for an English axle that i can use for drag racing i intend to put about 250hp through it any recomendations
britishtrident - 20/10/11 at 08:04 PM
I would look for a stronger axle. In circuit racing an engish axle will cope with that sort of horsepower but I would venture that putting 250 bhp through an english axle on sticky tyres from a drag racing start has great potential for DNFs
Of course it really depends peak torque and gear and axle ratios, a Rover V8 will snap a halfshaft quicker than a 2 litre Silvertop with the same or more power, the pinnion on short ratio final drive is generally weaker than pinion on a longer ratio (because the pinion gear has less teeth) and the effect of gear ratios is obvious.
Volvorsport - 20/10/11 at 08:35 PM
i think youll need a fully locking locker for drag racing........
tomgregory2000 - 20/10/11 at 08:50 PM
why not just weld the diff up if only doing drag racing? the locost way
