Have finally sussed setting up caster and camber but the top balljoint is only in by about 14 turns
(20mm ish) and this concerns me.
A simple solution is to raise the top wishbone mounts an inch or pack them out a bit (not keen)
so what would be the effect of raising the mounts which are currently to the book measurements.
Really don't want to remake the wishbones.
If its a book built chassis and suspension, why will it be so different?
My top links actually stick thru the inside slightley and have about 40mm thread holding them in (plenty)
I think that raising the mounting points will alter the amount of camber change
when the suspension is compressed.
My first set of bones I made to the book.
The second set have 22mm of off set (castor) and I also made them a tad wider
as I too was concerned that there was insufficient threads holding the drag link in.
The pic shows a new w/b tacked up in the jig with the old book w/b laying on top.
Unfortunately the camera angle doesn't show this very well.
Book w/b on top of modded w/b
Are your M18 threaded bushes long enough to be able to cut out and reposition?
It would save remaking the complete wish bone.
Paul G
The top ones on mine are are parelell to the ground at rest
the bottoms are at an angle of about 15% at rest,
i will post a pic once the car is out of the garage
BTW mine is book built exactley to the first edition book, so possibly is a differnt design?
As a min, you want the distance screwed in to be 1+1/2 times the thread diameter. If it was held by a nut the force would be applied to fewer threads
(thickness of the nut) than that so you can expect the threads will hold.
What is more worrying is that the extra length sticking out increases the leverage/bending being applied but they are designed to cope with the loads
applied through a fully (over)loaded Transit (though not in this configuration).
My rear upper mounts are screwed in just over that amount and have held for 13000 miles of abuse, although at some point, I plan to engineer a better
solution.
Attached is my front suspension at rest
The upper arms go slightley up say 1-2%
the lower arms drop more 5010% and both are the same amount even though the pics say otherwise!!
The top link, protrudes about 1mm, and is encased in 40mm thread
just for info, are your top links long enough, as i have a total of 67mm of avialaibe thread
regards
steve
Steve M - what did you mean by the typo error.....5010%
Ooops, i meant 5 - 10 degrees!
How on earth do the wishbones come out of that jig after they are welded?![]()
