can any of you help identify these uprights i think there from a courtina but im not sure they came with the chassis i bought but i didn't check
to see if the hubs i was given to go with them were the right ones before i got them anodized and have now discovered they don't line up
i
have loked for part numbers but all i could find was a ford stamp and the numbers 858
any help would be appreciated
[Edited on 22/10/11 by metro6r4]
they certainly look like my tina uprights
Yep tina,
Whats the kit ?
a Haynes roadster got as far as fitting the rear axle just started putting the front together and hit my first major snag
Hardly a snag, they are very much sought after and quite valuable!
Defo 'tina ones, and VERY shiny too
Haynes roadster front book uprights are from a sierra.
No big deal, some one will do you swap and pay for the plating.
i have the second edition and it says courtina uprights
so the question now becomes what are these?
Again tina.
Haynes roadster = Sierra
Haynes locost = Cortina
[Edited on 22/10/11 by big_wasa]
im getting even more confused witch isn't hard but if the hubs have four holes and the uprights have three holes how do they go together? i might just be having a blonde moment but im totaly lost
That second picture looks like a rear hub to me, the 4 holes bolt onto the end of the axle casing?
The 3 holes on the front uprights were not used on my car that used cortina uprights, sell they were used for the cycle wheel arch bracket mounting
only.
I was thinking more modern bolt on hub (land rover discovery style) but omitted to notice that the outer side of the hub has no splines on the inside to take the drive shaft!
Disc's are mounted inboard on them 4 spuds and not over the top of the wheel studs like sierra's and other modern stuff.
What doesnt line up ?
Any pictures ?
Is it a locost or a roadster ?
all sorted cheers bud i worked it out with a bit of help its a Haynes locost
[Edited on 23/10/11 by metro6r4]
