Inner tie rod replacement help...
jossey - 11/12/11 at 02:30 PM
Anyone know where I can buy the inner tie rods for my mk2 steering rack. It's a quick rack and has no play but the rack ends are trashed after welding extensions up which don't fit my new tiger :-(
I've looked about but without success..... Has anyone changed the tie rods before.....
Chippy - 11/12/11 at 02:36 PM
Picture would be handy, showing the parts that are stuffed. Cheers Ray
jossey - 11/12/11 at 02:43 PM
That is a tie rod.
Mine has been cut and welded
Ben_Copeland - 11/12/11 at 03:06 PM
Have you tried talking to Rally Design, as they sell the mk2 quick racks...
mad-butcher - 11/12/11 at 05:09 PM
Isn't cut and shut on steering components frowned on by vosa, certainly wouldn't fancy it myself
tony
jossey - 11/12/11 at 06:03 PM
tony
Hence the replacement
Would be ok for track day but not for road use
ashg - 11/12/11 at 07:45 PM
tony
if its done properly i cant see the issue. a prop is welded and fly round at stupid rpm.
britishtrident - 12/12/11 at 04:53 PM
tony
But a propshaft it isn't a slender strut in compression, and RWD Propshafts are generally seamed welded low carbon mild steel not high tensile medium carbon steel.
britishtrident - 12/12/11 at 04:57 PM
tony
Are you sure about that?
jossey - 12/12/11 at 08:16 PM
well unless you pull back the rubber cover you cant see its been welded which i would guess they wouldnt do.
Anyway im gonna get new inner rod ends so i will be ok as ive got proper extensions now.
ANYONE got any spare inner track rods please?
or a cheap mk2 rack i can buy?
