Just fitted these to my Indy and on the rear the centre caps don't fit as the driveshaft nut sticks out too far. Has anyone else had the same
problem?
Stu
Yep, the nut forced mine off and the tyre hit the shocker, so, 10mm spacers sorted mine, Although I reckon a 24mm offset would have been better but
thats in hindsight
And, then you'll need longer studs as well....
[Edited on 20/12/11 by coozer]
Thanks Coozer - I'll look into reducing the driveshaft bolt down a bit first as it doesn't need much to make it fit.
I've got no clearance problems on the shocker though the bottom bolt that goes through the wishbone and hub carrier caught the balance weights so
needed the end cutting off.
The car looks much better on 13" wheels though, particularly as the previous wheels were't the most stylish!
Stu
