Hello and Happy New Year to everybody!
I have an issue with my Sierra steering column. First of all it's the non adjustable type (with the alloy bracket) and i wonder if this is going
to work on the Roadster chassis.
Secondly i have made a probable mistake...
I have cut the column at an incorrect point. Not at the front near the rack but more rearwords, as you can see in the pictures attached. What i plan
to do now is to extend the column by using a steel tube with 26mm internal diameter and 30mm external. The circular section near the point of my cut
is 26mm, so i can extend it by using a piece of 30mm/26mm tube. And then i plan to mount it on the drivrer's bulkhead using a 30mm bearing, like
the one in the link:
http://simplybearings.co.uk/shop/p22815/SBPFL206+Oval+2+Bolt+Pressed+Steel+Bearing+Housing+with+30mm+insert/product_info.html
The big question is: Do you think this is a safe design (since the welding will be safe and strong anyway), or am i playing cards with the devil?
I hope i won't need to buy a new steering column..
If I'm understanding correctly I ccan't see why you would have a problem. My MK column is just extended with a pirce of tube welded on to
the Sierra column.
Stu
Originally posted by whitestu
If I'm understanding correctly I ccan't see why you would have a problem. My MK column is just extended with a pirce of tube welded on to the Sierra column.
Stu
As you say you have cut the collapsable section of the column . IMHO I doubt if it would pass IVA if any repair was spotted during the test
