Hi all
Im just playing with an idea and was wondering if you can swap the outboard drive stub from 100mm to 108mm without changing the hubs??????
reason i ask is i have a complete set of 100mm lobro shafts with stubs and hubs from a sierra and i want to use the hubs but then connect them to a
different drive shaft which has a 108mm lobro so can i just change the Stub for a 108MM one or do i need to change the Hub as well
hope that makes sense
cheers
tilly
