Anyone have an old Wilwood master cylinder
tasmod - 3/4/12 at 08:17 AM
After doing some brake mods I stupidly picked up a steel rule only meant as a straight edge, it had 15mm cut from end. I used this to measure off the steel pushrod from a single master cylinder in a bias bar setup. Result is it now only just fits, not a situation I'm happy with.
I need a pushrod, but these seem to be like hens teeth, nobody lists them, they require me to buy a new 7/8ths cylinder.
Anyone have an old useless cylinder with a pushrod spare?
Whilst doing the brake mods I've also discovered I need a residual pressure valve for the front discs.
Don't you just love making changes and discovering new niggles?
big-vee-twin - 3/4/12 at 08:24 AM
Would this do the job linky
tasmod - 3/4/12 at 08:43 AM
Well I never. I searched all over RD site and missed that.
Many, many, thanks indeed.
big_wasa - 3/4/12 at 09:14 AM
I binned one a few weeks back let me know of you want me to have a rummage ?
britishtrident - 3/4/12 at 12:27 PM
Years ago i made a push rod by grinding down a bolt. Stick the bolt in the end of an electric dril and grind it down against a bench grinder or flap wheel in an angle grinder.
tasmod - 3/4/12 at 12:43 PM
Thanks guys. As i'm ordering a brake valve from RD I might as well get a new pushrod for that price.
Gives me a new job to do. Insert brake valve in front disc line and whilst I'm at it fit the braided hoses I've had for a while. Must remember to fit valve after the brake switch, else I'll have lights on all time
Basically this is turning into a front brake overhaul
