reservoir to master cylinder connection
zekill - 16/4/12 at 04:12 PM
Hi all,
What are you do to connect a brake fluid reservoir that accept 8mm hose to master cylinder with 7/16 inlet ?
I try to found a 7/16 to 8mm hose adaptor without succes.
thank
big_wasa - 16/4/12 at 06:02 PM
If money is no object
Master Cylinder Union To Allow Push On Hose For Reservoir 7/16' UNF To 8mm Tail | eBay
Rally design do some that are 7mm for half that.
I made some out of brass that didnt look prety but worked untill I got some nice alloy ones at a better price than above.
zekill - 16/4/12 at 07:33 PM
My god, it's the same price for a new reservoir !
thx, I try to found another solution.
40inches - 16/4/12 at 09:24 PM
A bit cheaper CBS
zekill - 18/4/12 at 06:33 PM
thank, i have choose the cheap solution:
i have brased a 8mm ext diameter on the 4.8mm pipe and that work fine.
