I just fitted a set of 15inch x 7J et 38 wheels to the Velocity but they are rubbing the arches.
It looks like I need a different offset but I get confused about how to measure it.
I will need to move the wheel further in beneath the arch and therefore closer to the body by about 25mm. Can someone tell me the size I will need.
here's a guide on measuring them: LINKY
but something doesn't sound right here - what axle are you using ?
Ford Sierra running gear as standard.
I don't know the Velocity that well, but I thought most folk end up needing to space the wheels out - are you sure they are ET38 ? (the old RWD
fords used ET12 - ET25)
mk1 focus's (all the 4 stud ones) and mk3 mondeo's (last of the 4 stud ones) mostly use 15" wheels with 49 or 52mm offset if you can
borrow one to try it
(these are the ones I have on my tin-top)
[Edited on 22/5/2012 by mcerd1]
I have an old mondeo wheel here so will try that .
