Sierra hubs in Westfield rear uprights?
Minotto - 24/6/12 at 09:00 AM
Ooops. seems I've messed up.
I tried to fit my newly painted Sierra rear wheel hubs (off a model with disc brakes) into my newly purchased Westfield rear uprights only to find out that there is no way that they will fit. The bearings in the uprights are roughly 3 mm too narrow for that.
Help!
Should I have purchased different wheel hubs (and if so, what hubs are supposed to go in the westfield uprights?)
Can I go with another bearing? And if so, where to purchase one?
Any help much appreciated!
Hans
HPDxxx - 14/2/13 at 08:32 AM
hello, have you solved the problem?
i need to change my rear hub and i'll appreciate your help.
what kind of rear differential have in your car?
