Quafe diff sierra diff.
madteg - 24/6/12 at 12:23 PM
Will standard flanges/stubb ends fit into a quaife diff or do you have to bye quaife ones. Thanks.
[Edited on 24/6/12 by madteg]
Wadders - 24/6/12 at 12:47 PM
Sierra ones fit, but only the push in type....thats how it was when i fitted mine, things might have changed now.
maybe best to ask quaife.
Al.
]Originally posted by madteg
snapper - 24/6/12 at 12:48 PM
I think standard as the push fit Quaife takes the standard push fit shafts and they are the same splines as lobro stubs
AdrianH - 24/6/12 at 07:05 PM
I read somewhere, that for Lobro shafts to go into a Quaife ATB, there should be a grove for a snap ring cut into the splined section.
On the push in shafts they have internal springs that keep the joints from compressing, where Lobros can not. So to keep the end in place they use the snap ring.
In a standard open diff with stub ends there are C clips.
Adrian
[Edited on 24-6-12 by AdrianH]
