My mk2 escort steering column has play at the steering wheel end, and at the bottom of the crush tube end,
any one know a source of new bearings/bushs ?
Other options are to lose the outer column and just suspend the inner in rose joints on brackets.
I have the same issue. After making various 'slip in' plastic bushes on the lathe, none of which work very well, I am fast coming to the
conclusion that getting rid of the outer column and making some brackets up to take suitable new bearings is the way to go
I then got 'up-grade'itus' and started thinking that as I am playing with the steering column what about getting a new removable boss
with built in electrical connections so I can do away with the curly cable I currently have from the wheel to the dashboard....then I looked at the
price of electrical quick release bosses
If you find a source of the escort bushes I would be interested to know.
I also made a sleeve for the top bush, its a piece of a fosters beer can, wrapped round the inner column and held tight with a tie wrap
It does work, but not really the way i want to go!
Originally posted by peter030371
I have the same issue. After making various 'slip in' plastic bushes on the lathe, none of which work very well, I am fast coming to the conclusion that getting rid of the outer column and making some brackets up to take suitable new bearings is the way to go![]()
I then got 'up-grade'itus' and started thinking that as I am playing with the steering column what about getting a new removable boss with built in electrical connections so I can do away with the curly cable I currently have from the wheel to the dashboard....then I looked at the price of electrical quick release bosses![]()
Lifeline do a 'formula' boss with 8 pin electrical connection for around £280 or if you want the bigger 'touring' boss you are
looking at £400!
I have recently seen that OMP do a boss that 'has the facility to accommodate wiring' so I assume a certain size/ style of connector can be
fitted but I have not yet seen the cost of these extra parts. The OMP boss itself is around £190 so its hardly 'cheap' by my standards
I have a spare Mk2 escort column hidden away in my garage if its any use ? I'm 99% certain the bearings are good , but would need to check .
Burton Power do replace bushes in nylon.
Just been looking myself.
Matty
