I have a Sierra Diff with the 100mm flanges. I bought a set of drive shafts from a breaker thinking that only the Cossworth had the 108mm Lobros. The
ones I bought were from a 2.9 BRG.
However when I got them they were 108mm so I now need to source a new set. Just wanted to confirm which Scorpios I can get them from as I don't
want to repeat the same mistake again.
Anyone have a list of which models have the 100mm lobros?
this should help
http://www.locostbuilders.co.uk/forum/9/viewthread.php?tid=85080
I think that link is about diff codes, or am I missing something?
Eitherway, this might help http://www.jandrcvjoints.co.uk/sierra-saphire-scorpio-granada-inner-cv-joint-100mm/
Thanks,
That site showed that there is indeed a difference with the 2.9l engine so I need to pick axles from the models in the list provided in your link.
Although given the prices on that site I'm better of buying new from them rather than having the hasle of fixing up old ones that are in most
cases more expensive..... I pretty much get 4 new joints from that site for the price of one old axle from a breaker here.
The 100mm lobro are fitted to 2.0litre and 2.3 petrol scorpios .The 2.9 . cosworth . and the diesel are fitted with 108mm
