I would like to have a set of front top wishbones made up, which would move the existing ball joint rearward by around 25mm (to give more castor angle
to help with the self-centring and the feel through the wheel).
I know what there were a few folk on here who can do this sort of work, from either a drawing, or one of the original wishbones - but I can't
think of who!?
- Wozsher?
- 907?
- Welderman?
Wozsher made a set for me 1-2 years ago now, but having checked the members list, his last activity on the site was 20/7/12 at 15:41
Liam mcaffrey iirc
Talon made a set of rose jointed top front wishbones for my Indy, a car known to benefit from an extra bit af caster angle. They were very precisely made and decent value. He makes Haynes chassis for a living and is completely reliable. I would reccommend him.
I can, I have done 1 set for Callan and am doing a second set now. Do you have a drawing? I could do it from a standard bone too.
old set I did for my car
[img]
top bone
[/img]
[Edited on 3/4/13 by liam.mccaffrey]
I made my own for the same reason, isnt particuarly hard, make a jig, cut, grind, weld, lick of paint.
I,ll make you some if you like, I,m not that far from Southhampton, 40 miles intact so I you want to pop around at the weekend with your old bones we
can modify to suit if you like.
Regards Mark
As Mark says, modifying your old bones is probably easiest. Particularly if they have poly bushes as changing from bushes to rod ends gives them lots
of adjustment.
I did my own without too much effort.
Stu
We can, not urgently if you need them quickly though. Could potentially do aero section if you were interested.
Like: http://www.facebook.com/photo.php?fbid=471215356280359&set=a.267713003297263.62633.153409081394323&type=1&theater
Originally posted by twybrow
I would like to have a set of front top wishbones made up, which would move the existing ball joint rearward by around 25mm (to give more castor angle to help with the self-centring and the feel through the wheel).
I know what there were a few folk on here who can do this sort of work, from either a drawing, or one of the original wishbones - but I can't think of who!?
- Wozsher?
- 907?
- Welderman?
