Vauxhall brake mount dimensions
turbodisplay - 27/5/13 at 07:51 AM
Just been designing a front upright to replace the vectra hubs I was using. So giving me caster, camber, toe and limited kpi adjusability. Have seen that the Vx220 hub, being elise based will most likely be worth considering.
Problem is I cannot seem to find the dimensions for the brake mounts, most importantly is the distance from the centre of the hub.
I`m sure in the past I have seen it somewhere on the internet before, but hours of searching has proved fruitless so far.
Thanks in advance. Darren
