peddle box ect
simonsmith - 21/10/04 at 10:30 AM
Hi, i'm builing a locost and i'm having some problems with the peddal box and surround. could someone email me with how they did their's. I found that mine is very heavy, especially the back plate and would certainly not be suitable for competing in races. Thanks for your help..
JoelP - 21/10/04 at 12:17 PM
you dont need a box as such, unless you need to move it. i just welded pedal brackets straight to the chassis.
chrisf - 21/10/04 at 05:18 PM
Can you post a picture of your's? That might be more helpful.
JoelP - 21/10/04 at 06:30 PM
sorry mate, camera phones in for repairs for a few weeks.
clutch and throttle cables are simple, just make a 4 or 5 to 1 pivot pedal, a bracket from 25x3mm strip, and tack it in place. Then use some 19mm round tube to hold the cable outer in place. a bit of fiddling later, voila!
i made my brake pedal top mounted, to make it easier to get the MC at the right angle. The others are bottom mounted.
chrisf - 22/10/04 at 01:21 PM
Simonsmith should post a pic of what he's talking about. That might help us both. I'm finishing my pedals this W/E, so perhaps I could post some pics--if interested.
--Chris
James - 22/10/04 at 06:03 PM
Make your own- they'll be a fraction of the weight and can be bottom mounted so you make better use of otherwise wasted space in the car.
HTH,
James
