I'm looking for a 250mm long brake reservoir feed pipe for my car. I got one with the pedal box, but it's far too long and not very flexible. Anyone know where I can get one?
From wicket's post in http://www.locostbuilders.co.uk/viewthread.php?tid=178533
Fiat Seicento p/n 46774776, 290mm long (the longer of the two options)
Resevoir to m/cylinder hose
CBS sell the flexible stuff with over braid, they also provide a certificate to prove its suitable for intended use which you need if your going thro IVA.
Out of interest, could I not buy two fitting and tube it in copper brake pipe, or is the bore too small for a feeder line?
