Hi was at my mate today and he is restoring a xworks rally cross metro we were wondering what the wheels were of as metro or ford or mini wheels don't fit .i measured across the wheel studs and it was 11.5mm centre to centre of the studs.someone on here might no what the wheels came of and hubs on the front of the car thanks Jonny
You mean 115mm surely? Assuming its 5 stud then I would guess at being the same as 2005 onwards impreza sti which are 5x114.3
The value you have is not PCD unless is stated in cm.
If it is 4 Lugs and value in cm, closest PCD is 114.3 mm
How many lugs does it has? 4 or 5?
Hope this helps.
Austin Metro as standard was 4" (101.6mm) - I think the 6R4 was also 4"?
Rover Metro as standard was 3 & 3/4" (95.25mm)
ETA both 4 stud
[Edited on 28/12/13 by scimjim]
for 4 stud: try tr6 or mgb, and some Japanese.
ps 114 is 4.5inch
edit
give us a photo of the hub unit, someone should recognise it
[Edited on 28/12/13 by gremlin1234]
also it's front wheel drive so it would not be tr6 or mgb as there rwd and it uses maxi cv joints so could it be possible for maxi or 1100austin
http://www.carlsalter.com/rover-wheel-fitments.html
If it's a rover hub then 600, 800 or Maestro Van (!) were all 4 x 114.3 ET35
If Austin the Maxi/Allegro fits with 114.3 x 4
114.3mm is 4.5" BTW
114.3mm is 4.5" BTW
4x114.3 is pretty popular in jap stuff, civics and such use it so wheel choice should be pretty broad
