Hi All,
I need a new bush for one end of my Panard Rod.
OD is 1 1/32"
ID is 1/2"
Ive had a look round the internet and cannot find anything suitable... any ideas?
What material?
I could probably knock one out in delrin in work, but being a plastic it won't take any out-of-plane bending, however not sticky or squeaky
Thanks, but it doe need a bit of movement. so rubber or poly is what I need.
Im getting the feeling I'm going to struggle with this one.
Try these http://www.antivibrationmethods.com/product/bp-bush
Give them a call, sure they could find something.
Hi there. I've got a 1 1/16" OD metalastic bush you can have. You might reduce its outer dia to suit. 1/2" ID. 35mm overall length.
Looks like this...
The 1 1/16" ones are the same as I used in my striker arms
Here http://bit.ly/1f5ylqZ
Thanks all, I've managed to order one.
Will let you know how I get on.
Quick update:
A 1 1/16 bush was sourced as multiple bits of research pointed towards it. Fitted today, twas really tight to fit but did go in with the help of mr
vice.
Thanks for the help all.
