I'm after a pair of front bottom wishbone ball joints for a Mk1 Mx5..
Eurocarparts want £50!
http://www.eurocarparts.com/ecp/c/Mazda_MX-5_1.6_1990/p/car-parts/suspension-and-steering/suspension/suspension-arm-and-suspension-joints/?61768066J&a
mp;1&9ddcc9e26d7d916b74decfffd7a2fc8cac3e46b6&000019
Is there another option?
http://www.mx5parts.co.uk/suspension-c-69_70_241.html?page=3&sort=2a
WOW
Anyone got ant knackered ones? Just so I can setup the bottom wishbone..
I've got one that will never work again as a ball joint, but it's perfect to line up the wishbone plates for alignment. You'll still
need to buy new ones for your finished car though.
You can have it for postage costs if you want? My wishbones are all welded up and ready for good ball joints.
I also found new ones here;
(Pair) MAZDA MX5 Mk1 Eunos Lower Ball Joint Joints x2 (1989- 98)
A bit cheaper for a pair.
[Edited on 18/4/14 by Slimy38]
Yep, just looking for one to weld up the wishbone!
http://www.mx5nutz.com/forum/index.php?showuser=3617
If you are on the MX5 nutz forum give this chap a PM. Or ring him is number is on his profile. Might take a couple of calls at different times during
the day to get hold of him.
He is cheap with good postage prices. Failing that I have a good one you can have for postage..
