Hi guys,
I am searching for a supplier of Metric (M12) polyur. Bushes.
The rallydesign PB121/122 are 0.5 inch (12.7mm)
So are most (if not all) on Ebay...
Checked all the most used kit car parts webshops...
And MK has them om their wishbones, but can't find them on the webshop.
thanks
Originally posted by drt
Hi guys,
thanks
Mine were M12, or at least they're a good fit on the M12 bolts I have. Unfortunately the supplier is no longer a user on Ebay, but these are
similar and they specifically point out they use a measurement that is closer to 12mm;
Haynes Roadster Locost Wishbone Bush set - Rear in Black Polyurethane
These bush/crush tubes are for 12mm bolts, the crush tube is mild steel zinc plated and not stainless as they are supposed to be but other than that
they fit the 12mm bolts pretty snug
Haynes Roadster Locost Front Wishbone Bushes in Poly
Thanks guys
I saw all of these articles.
They all stated 12.5 or 12.2 mm.
That put me off.
Thanks guys![]()
That put me off.
Any reason for sourcing 12mm bushes over sourcing 1/2 inch bolts?
Oh and,
A m12(1,75) bolt has a production tolerance between;
11,966 and 11,701 mm
A 12.1,12.2mm crush tube will not do.
If your that concerned with tollerances you should be looking at rose joints and rod ends.
What do you need polybushs on a hub for? Every one I can think of is either a ball joint or a bolt..... And even if they are designed for a bush, if you've got rose joint inner ends, poly outer ends seems a bit odd as it will just introduce movement where you don't want it, especially if you're that fussed about a 0.5mm tolerance on a crush tube.
Also on the lookout for metric polybushes...
metric
What do you mean by a bolt ? Just a bolt in a tube welded to the Wib (wishbone)?
Then... :p I could have guessed it woud come to this ...
Rose joints, rod ends... if they are the threaded shaft type, so not uniballs.
must never be use in shear !
To do so is a bodge (and a sin)
When I move from pull-rods to push-rods -directly on the hub- than its ok.
Seems that is the best solution
any access to a lathe? you can buy polyurethane bar, usually 90 shore A i think.
I'm considering getting some for bushes. i'll use delrin or nylon of somesort in my tube chassis wishbones though.
Would that be any good, if you want to have a precise suspension setup. would guess they'd be between poly and shperical bearings
What hubs are you using? It sounds like nylon, or a similar hard plastic, may be better for you than poly bushes as they'll remove 95% or more of the movement but still allow rotation.
Nylon bushes still need a stainless steel crush tube. They look just like a poly bush set up, but with virtually no play.
My first version engine mounts use nylon, as I have very tight clearances, and they look like this. Just need to fit the stainless crush tubes now, as
the one pictured is mild steel.
aaah, I see.
Yes a PA66 bush would be the dream
Sadly I lost access to (my) lathe.
That is why I needed a supplier
Why do you have nylon engine mounts ?
Mainly because I had nylon bushes lying about ready for my front suspension. But that's weeks/months off yet, and I didn't want to wait for anything else to arrive in the post. And I only have about 1/2"-3/4" clearance in places round my engine.
And my bushes and brackets came from Russ (?) at Furore Cars.
I know, but it gives me a little wiggle room on the bolts. They are also just a Mk1 engine mount, so I can change the bush later on with little
hassle.
Also, try this place. They appear to have a minimum order of £50, but their prices seem much cheaper than
anything else I've found. Ones the same size as mine are £0.48 EACH, but they do come in bags of 100!
That is solid gold
thanks!
I'm a designer now, but have access to a lathe in work. Some delrin bushes wouldn't be hard to knock up if you like.
by the way nylon is horrible poo to machine, melts really easily compared to delrin's beautiful machinability.
there are a few plastics i've seen, 'nylatron' comes recommended, nylon with molybdenum in i think
