My 3 wheeler is coming on and everything I do improves it a bit, but the rear isn't quite as stable as I'd like. It has a single rear wheel and still has the original bike tyre on it. I've been wondering if having a bike tyre on it is part of the problem. Will a car tyre fit on the bike rim? Is my local tyre place likely to be able to fit and balance it OK?
Yes, 'venom project' uses a car tyre on his tr1ke
Think of the physics involved - a bike tyre is designed for the bike to lean into corners...if your trike isn't leaning then you've only got
that contact patch in the centre of the tyre doing any work - the rest of the tyre is redundant; you're never going to use it...hence car tyres
are flat...
BUT in answer to your original question - yes a car tyre can often be fitted onto a bike rim.
It has been done on bikes before, I believe its called darksiding.
Bike tyres bead the same way as car tyres so as long as you get a tyre designed for the width of the rim you should be ok.
Thanks everyone.
It would be a good idea to replace the bike rim too, if that's what you're using. Bike rims are not built to take lateral forces.
It's a very common thing to do in the USA/Australia on the Triumph Rocket III
Pat_T ^^ but that looks just so wrong.
Presumably there are only straight roads in US and Oz?
Cheers, Pewe10
being an ex-biker, i'm curious.....
What the hell happens when yuo lean it into a corner? surely you have naff all contact patch and fall off?
Also, there must be a horrible sensation as it goes onto the 'corner' of the tyre.....
There's plenty of shoulder on most car tyres. This vid shows about half the tyre being in contact when cornering. He isn't getting his knee down though.
https://www.youtube.com/watch?v=gZKhoFbL7Fo
I have ridden a bike with a car tyre on it and it was truely awful,like rideing with a flat tyre.you have to counter steer so much to get it on to the shoulder its horrible.best left to the "harleys and crusiers really handle and go well" brigade.
I've finally got round to taking off the back wheel to have a car tyre fitted and my local Kwik Fit flatly refuse to do it. Is this something
they're all going to refuse or is my local place just being awkward?
Where do bikers get their tyres done? Do they go to a tyre place to to a bike shop?
Take it to a one-man garage and bung him a tenner...
I've finally got round to taking off the back wheel to have a car tyre fitted and my local Kwik Fit flatly refuse to do it. Is this something they're all going to refuse or is my local place just being awkward?
I've finally done it. With a bit of persuasion, my local bike shop did it for me. The tyre looks right on the rim, but if anything, the
handling of the trike is slightly worse than when it had a bike tyre on the back. At least I've ruled out one more thing.
[Edited on 29-9-2014 by smart51]
