I have Protech 400 single adjustable dampers on my car. I am trying to work out which way the adjustment works I,e clockwise and anti clockwise. The more anticlockwise I turn them, the harsher the ride seems to be. Is that correct?
Yes. Clockwise stiffens the damping! Are you on the 13 click adjustable ones? I usually run mine on circuits at 7 clicks clockwise. With front arb fitted but no rear arb. Mine have rebound adjustment too which I set slightly different front/rear
Protech shocks have three postions (soft, medium & hard) with 13 clicks within each setting.
After assembly the unit is tested with the very latest computer controlled damping dynamometer to establish damper conditions and calibrations. All
units are set with an adjustment range to suit 95% of most applications. However in the event of needing a lower range of damping or a higher range of
damping this can be achieved as follows on or off the car
Turn control knob to off position (Anti-Clockwise) then turn six clicks clockwise
Holding knob firmly against shock absorber unscrew 4 m/m grub screw in the side of knob by one half turn
Still holding knob firmly against body turn control screw in centre of knob with screwdriver half a turn clockwise to increase damping range or
half a turn anti-clockwise to decrease damping range
Lock-up 4 m/m grub screw
Holding the knob firmly against body at all times this prevents the spring and ball bearing coming out of it's location - if this happens you
will lose your "Click" action which means removal of knob to correct
[Edited on 23/6/14 by jeffw]
You may be sprung slightly stiff as it's the springs which control firmness of ride. Try 7 clicks on front 5 on rear and see how it feels
Thanks Daniel- I will give those settings a try and see how we go.
The springs are those reccomended by Saturn sports cars when they were building Haynes roadsters. Rear are 350lbs and front are 250lb.
Are the springs equal length? If so swap them over as I think you may be too stiffly sprung at the rear. I'd imagine the front should be a fair bit stiffer than the rear but am in familiar with the Saturn geometry! Is it an IRS rear end?
