Trying to improve my braking distance so have fitted drilled-grooved disv and got s set of mintex 1144 pads.
On the box it says: this material must not be used on public highways.
So should i fit them or not?
Also in the box are four self adhesive pads. I am guessing they go on the back at the front, similar to the steel shims.
Do I used them without the shims or with the shims? Or not at all?
I dont race round like crazy but more or less pootle along - my understanding is that certain compounds work better when hot , something not likely
with my style of driving.
I looking for good grip with cold discs and pads.
[Edited on 30/7/14 by 02GF74]
I have them on my J15, at 500kg and 125hp the brakes work great from cold, hot and trackdays
I put the sticy pads on and use shims, no problems.
Good pad for kit cars I think.
[Edited on 30/7/14 by monkeyarms]
Fit them; You'll notice a big improvement. I would fit the shims as well as they are known for squeeling (though I've never suffered). There
was a thread last week with the correct bedding in procedure.
Drilled/grooved discs won't improve stopping distance under normal circumstances. They'll just reduce glazing (while increasing wear rate)
and reduce fade under extream use, when the pads start to gas.
Where did you stick the pads?
I am guessing the front hallf at the back and make small hole for the pin?
Off to google as i am sbout to fit them.
1144's are fast road
1155 are track
Check your numbers
Or
Perhaps
They were imported from a country that does not allow these modifications
Mintex 1144 best thing I ever did for my Locost/Cortina brakes...............
Don't hesitate.
1155 are track
Check your numbers
Or
Perhaps
Mintex 1144 pads may not conform to European Standards but you will be able to stop BUT you could get sued or not paid out by insurer if you have an
accident
OE pads will conform but will only make a mild rubbing noise , with little retardation so you are more likely to have an accident ,but at least you
won't get sued!!!
..........I'm getting OLD!
[Edited on 31/7/14 by Surrey Dave]
How could anyone tell what brake pads you have fitted anyway , even with a strip down!
The only major case involving upgraded brakes I know of was a serious one involving an idiot who fitted a Range Rover front calliper to one side only
on LR Defender.This would give almost 50percent more braking on one front wheel.
The consequences were tragic but nobody on this forum is that big an idiot.
[Edited on 31/7/14 by britishtrident]
The only major case involving upgraded brakes I know of was a serious one involving an idiot who fitted a Range Rover front calliper to one side only on LR Defender.This would give almost 50percent more braking on one front wheel.
