Cortina upright to spherical bearing adaptors
Fred W B - 7/8/14 at 05:35 PM
Evening all
I'm looking to either source or have made some Cortina upright to spherical bearing adaptors . Before I spend a lot of time on google or drawing maybe someone has a link to a supplier or drawings of said parts they would be willing to share?
Regards
Fred W B
[Edited on 7/8/14 by Fred W B]
coozer - 7/8/14 at 07:02 PM
McGill Motorsport sell the bearings and cups.
The Midlana is designed to replace the top ball joint with a spherical.
Doctor Derek Doctors - 7/8/14 at 07:56 PM
I have a full set of tapered pins to convert Cortina upright to use 5/8 spherical bearings top and bottom. Made by David Dickerson (can't remember his user name) from this site, from Stainless steel. Also have a set of strengthened Rally Design wing stays that clear them.
Edit just spotted you are SA which is a bit far away. I will look to see if I still have the drawing I did to have them made from.
[Edited on 7/8/14 by Doctor Derek Doctors]
Fred W B - 8/8/14 at 04:22 PM
Thanks for the responses
That would be appreciated Derek
Fred W B
