As per title, I'm after L/H & R/H rear wheel bearing kits to fit 100mm lobro type hubs.
So far, local motor factors approx £38/side
eBay is a minefield and descriptions are so poor so can't tell which type
carparts4less have some for £22 but only list stock for one side.
Anyone bought some recently and have any links?
ta
Can't help with a source, but you may wish to consider quality over price.
I would stick to proper brands (skf, timkin rhp. And so on)
Turkish/polish bearings may fit(stumbled across a few that don't despite the supplier double checking and then suggesting the bearings I took off
the car were wrong!) But even then longevity will be an issue.
Edit try here
http://simplybearings.co.uk/shop/product_detail.php?products_id=754053&gclid=Cj0KEQjwvLGfBRDfkrr19KDS-7YBEiQA8CoFJxKoTTBMKnHWUL3tN_x9LgyIL1Y6i9Wal
bPAbKEFSkcaAvuC8P8HAQ
[Edited on 15/8/14 by cliftyhanger]
I went thru ebay in the end, £5.50 each. Just made sure I measured them as there are a few types. Fortunately theres quite big differences. Just dont rely on part numbers alone as they often get mixed up.
