hi all,
my kit will soon need new tyres, any recommendations please, running 185 70 13" at the mo, will be staying with 13", have toyo 350 on it
now, not worn out, tread has started to get cracks between tread pattern.
andy
Toyo R888 or Yoko A048.
You will be AMAZED at the difference.
I went from a539 and haven't looked back!
Same as what he said
I third that
Avon cr500 get my vote but might not be the size you want
[Edited on 20/8/14 by Dopdog]
Sorry for the hijack but I am also looking for recommendations for 13" tyres, specifically for wetter conditions. Currently running Avon A048 which are great in the dry. I want to save these for the summer and get a set of something more suitable for the darker months. Anyone tried the Toyo T1-R?
Hi
Personally i'd save my cash and buy the cheapest tin top with a working heater and 6 months MoT I could find for those wet dark days
The smallest T1R's are 14's I think?
But if you're serious about it:-
The posts above illustrate how most Tin Top orientated tyres are way too hard for a 7, so to get a Wet to work you're really looking for a
soft(ish) 'performance' tyre in a full wet pattern.. tricky..
But I'm lead to believe if you talk to BMTR nicley they'll cut an Avon ZZR to a full wet - make sure you tell them it's for road use so
you want A60 compound..
The new Avons?
http://scottish-kitcar-centre.mybigcommerce.com/avon-zzs-215-55-13-and-185-55-13-tyre-set/
