What are the thread sizes on mk2 Escort steering rack and lower wishbone ball joints? I've lost my nuts and don't have any in my garage that fit. They're definitely imperial size. (Who keeps spare imperial nuts these days!)
Mk2 will be metric (mk1 was imperial)
Track rod lock nuts, m14, ball joint studs, not sure, can only be m8 or m10 though?
Ah, if they're M14 that could explain why the M12s weren't quite going on. Pretty sure the ones on the steering arm aren't M10 though.
The lock nuts for the track rods on Mk2 are M14x2. Ie they are 2mm pitch. Take care you get 2mmm pitich not the more common 1.75 pitch.
The balljoint retaining nuts could be anything as different component manufacturers used different threads you will need to measure them with
callipers and a thread pitch gauge. It is not impossible for them to be UNF. NB. UNF is an inch thread BUT it is not an imperial thread.
Ok, I've measured the ball joint threads and they're about 11.0 mm and 11.8mm. Any idea what they would be? They're definitely not metric. Without a pitch gauge I could buy nuts and see how smoothly they fit, but I need a starting point.
