Just wondering if anyone can offer any advice....
I'm planning to use the stock hubs and breaks of my donor car (RX8) the side effect being you cant fit anything smaller than a 17" wheel
over the calliper.
I want some pretty wide tyres as the thing will be pushing 350+bhp by time i'm done and going to need all the grip i can find.
Thinking something in the 255-285 range!
Of course this means really low profile tyres too, 30-40
Ride quality of is no concern to me, going to be fully rose jointed wish bones. It's all about handling and performance. But is there anything i
should know about putting such big wheels on that might be an issue? Handling, control etc, wise?
Ta muchly
you need lots of tyre wall on a 7 to give predictable handling, fit the combination your suggesting and a similar car on 13" wheels will run rings round you.
Can you explain why?
Obviously rolling diameter plays a part in acceleration.
Does not having a lower profile tyre equil less tyre deflection when cornering and thus better handling?
I could be totally wrong there, but I'd like to know how and why it effects handling rather than just a statement
Will be about getting heat in the tyres. RX8 will weigh 3x as much as most kits. Wider and lower profile will not give you any latteral movement in
both tread and sidewall.
brakes that size will be unnecessary, either change the brake choice, or reduce the disc size and customise the brackets so you can retain the
calipers. 15s is as b7g as you want to go on a light car, and even then 13s are considered optimal.
Big alloys the size you suggest are heavy. The effect of that much unsprung mass will not be good.
Aquaplaining is another problem as is the loss of steering feel.
I doubt you'll need a rear tyre in the 255-285 range. Remember you should have very little weight to shift and going wider creates more issues
with added weight, tramlining, aquaplaning etc You'll probably find a good sticky 225 (even 205) rear and 205 front will be more than enough.
Maybe some of the high powered turbo'd guys on here can back this up?
Mine should be good for 230+bhp and I'll be sticking to 205/50/15s all round.
Ok, there are some sensible reasons to go with smaller here.
From best i can tell if i upgrade the breaks to 4 pots the callipers are actually smaller (go figure) and can get a 16" wheel on.
If i modify things a bit i'm sure it won't be too hard to get away with a 15".
Maybe something like 235/50/15 will be sufficient.
Originally posted by Doctor Derek Doctors
Are you using the RX8 front uprights/hubs as well? Will be interesting to see how the geometry i when fitted to a Seven with Double Wishbone suspension.
My main question would be is it a road car? If it is then fully rose jointed wishbones/suspension are going to make the vibrations on the road pretty horrific. If its a track/race car then its worth doing but on road driving it could be utterly unbearable, especially when combined with large wheels and low profile tyres. It will also put loads more wear and fatigue into the suspension and chassis.
I dropped from 15 to 13" wheels and the cars compliance, handling and predictability improved massively, making it much faster round a circuit.
It's ok living with the ride, but as a hillclimber it will not be very much use are all!
The car needs to be as light as humanly possible.the chassis as low as possible (but enough to clear speed bumps if road legal) but most of all it
needs compliant handling and ride. I'd go watch a hillclimb and see what everyone else In class runs. And when you do you'll see they nearly
all run 13"s and a well sorted geometry setup!
Light weight will be easy, I'm very lucky to work for a company that has a whole site dedicated to making composites that I will be very soon be
next door to, and I'm a CNC Machinist. Carbon fibre will be featuring heavily... I'm aiming for something around 500kg or lower.
Getting 13's on will only be possible if I completely scrap the standard breaks and heavily modify the hubs.
Donkervoort uses on their D8 GTO Toyo R888 in the sizes 215/45 R17 and 235/45 R17. 8x17 and 9x17.
The D8 GTO might be an interesting benchmark to your design.
Its performance does come with a price.
But a 200hp rotary will do nicely in a Haynes Roadster.
As for the wheels Donkervoort are using Japanese Rays forged alloys weighing around 6.5kg, which is quite light for a 17" wheel.
Donkervoort also uses Tarox brakes. Alloy 4 or 6 pot brake calipers can save quite a bit of unsprung weight compared to cast iron ones.
My performance figures have changed a little, i was offered a 13b REW and just couldn't say no. So now i'm looking at about 450bhp
I was surprised at how heavy the GTO is!
If i can use 17's will make life easier as everything can be standard, maybe 16's if i upgrade to the slimmer 4 pots. Impressed at 6.5kg for
a 17" wheel. Well worth a look at!
Getting unsprung weight as low as possible will always help.
