Hi Everyone,
I have had the 2 parts of my steering downlink extended by cutting them in half, sleeving them and welding them. I would like to pin each end of the
sleeve to the inner shaft using a roll pin as a safety device - would this be acceptable for IVA?
Shaun
I did exactly that and also welded the roll pins in afterwards. No problem for IVA.
Stot
Yep, that's exactly what I did.
I did the same
1Thanks guys will crack on tomorrow!
I also did the same, yet for my sanity, it was "belt and braces"
steve
Mmmmm, you shouldn't weld roll pins. The heat messes up the structure.
A very apt comment by Prawnabie. "Will crack on tomorrow"
Paul G
