help just fitted steering rack i came to connect the bottom column link to the rack to measure and lengthen it and it,s to big it.s off a sierra dohc it does tighten down but seem,s to have to go along way what should i be using ?
What rack have you used? Are you referring the the yoke that fits onto the rack input shaft?
Ive used the column and rack from the same DOHC donor so obviously no problem to fit. Do you have the column that mates to the rack - can the ends be
changed over? just a thought.
A pic might be useful so we can see how your current set up is fitting together. The yoke has a pinch slot, is this slot fully closing befor ethe bolt
gets to torque? Is the bolt located through the cut out in the racks shaft OK?
using mk2 escort quick rack and sierra lower yoke it,s a luego velocity and it,s what they describe in the build manual only thought i have had does sierra with power steering have a larger input to the rack as i think my link could be of a p.a.s sierra
Yes, Sierras with power steering are bigger, go down the scrap yard & get another,
[Edited on 26/11/04 by planetester]
bugger back to the scappy,s next week when i,m off shift again thanks though
mine wasnt cast, it was forged, I cut it in half, turned up the ends to fit my tube & it welded great. trust my life with it
