Want to build a 2 stage propshaft for my 6x6 truck after seeing the setup on a ww2 American deuse and a half aka the 'jimmy'
So looking for a suitable bearing pillow block thing with a internal 6mm shaft diameter for the middle.
Was thinking of using a rose joint but will it take the rotation ok?
Is this for a model?
Why not just use a 6mm pillow block? Personally I wouldn't use a rod end.
Regards
Davie
Regards
Davie
