Hello.
I'm in the process of building a Haynes Roadster together with my brother. I have drawn the car in CAD, but I haven't found any 3D model or
drawing of the transit tie rod end. I would like to do some basic analysis of the suspension, and therefore I need a 3D model or drawing to check the
geometry.
Is there anyone who can supply me with such or point me in the right direction?
Thanks in advance.
I have all the info
what format do you want
I have solid works
And autocad 2d
I'm using Catia V5 and I'm not sure if the program can read, or not, these formats. Could you send me both, to rallyelwood@gmail.com?
I believe catalogue v5 will open solid works native files
I'll send iges as well
What parts do you want
I'll have to draw them up
Will be Tuesday as out tomorrow
Sounds good, thank you.
I need the complete joint if that is possible.
I have a Transit TRE in Sollidworks 2014, both parts, mated at the ball, and the assembly...could convert to pretty much any format you'd
like.
Not trying to out do Bart...just giving you another option....
Let me know.
Alan
Attention rallyelwood
I think you tried to u2u me, but I can't open the message.
Use my email if you like..
meerkatguy1956athotmaildotcom
Ignore this.....I just found the U2U window hidden behind a ton of other windows...
[Edited on 19/2/15 by Alan B]
please carry on , i'm really up to my neck with work so have no spare time even for my own car at the moment
not offended at all more relief !
