I was advised that I had some play in the UJ on the steering column. So with the nice weather I thought that I would look to replace it.
started this afternoon, and am confused. It has the sierra triangle female part, but the other end of the UJ is welded on to the column going down to
Is this normal? How do I replace the UJ then?
Sorry for the idiot questions.
Car is an MK indy.
Craig
Got a picture of it?
I have tried to put the image below
steering column 2
but it not worked then in the photo archive
[img]http://
steering column 2
[/img]
[img]http://
steering column
[/img]
left of the pictures is the scuttle and the shaft goes down to the rack.
[Edited on 15/2/15 by aka Keith]
Looks normal for a shortened steering assy. Could the play be in the firewall bush? I've used a self aligning bearing in mine.
The play is definitely in the UJ circled and the weld on the left hand circle.
how do I replace the UJ?
[img]http://
[/img]
Grind off the uj and weld on a new one. I am just building mine , it's just a ford Sierra uj its welded to a set length piece of round bar , uj
is welded to one end the other is welded to the rubber part that fits to steering rack.( not literally welded to the rubber part)
When building an mk , mk themselves modify this part for you .
Hope this helps thanks nick
thanks Raptor, slight problem is that I do not have welding facilities. Are there any other options?
Sure someone local will weld it for you, if I wasn't so far away I would do it for ya!
I would remove the bar and check the other end is ok maybe replace that too. But no other option that I can think of
Unless you want to look at changing the column section for a different shape, ie triangular, and have new bolt on joints, the only real option is to get a new UJ welded on. If you can cut the old one off cleanly and clean the column up, it'll only take a few minutes to weld that. Few quid in cash should see it done at a local fabricators.
Carbuildersolutions do a sierra to escort UJ which you can bolt to a escort spline. How long is it? You can get a splined shaft in 300mm, 400mm or 600mm I believe.
One here on eBay new
Cut of the triangle part weld in the same position as your old one
Job done .
http://pages.ebay.com/link/?nav=item.view&alt=web&id=131430410247
cheers Raptor.
Many thanks.
Craig
Try this people, they sell all manner of splined columns and parts...
http://www.popbrowns.co.uk/
