Got a Girling Tandem Brake Master Cyl on Kitcar with a tag around it.
The number 66 198 02 50/50 40P0, but cannot see any other than Girling cast on the body and its horizontally fitted not at an angle.
Anyone identify it please.
Post a picture, or a few, that always helps.
Here are some Pics of the Cylinder to help.
Also it's connected to Escort MK2 Calipers and Escort MK1 Axle.
[img]http://[/img]
[img][/img]
[Edited on 22/2/15 by sooty]
Its from an early type Ford Fiesta (up to '83). Has bore of 17.8mm dia.
Hello Dick - I was just about to send you a U2U to see if you could help
Thanks Dick,
The only Master I can find for the Fiesta, show the mount flange at an angle, where mine is horizontal.
And the only Master I can find near, is either a PMC101 or PMC157.
Do you have a part No. for the one shown or should be looking for.
Thanks again
