Hi,
Anyone got a pinch bolt recommendation for escort uj's?
Thinking high tensile M8 bolt or high tensile UNF 5/16 both with smooth part in the groove.
Jon
CBS do the following
http://www.carbuildersolutions.com/uk/516-unf-high-tensile-bolt-and-nyloc-nut
Thanks, seen that but was wondering if there is something designed to fit...
How do you mean designed?
The joint was designed to use the bolt linked to!
Check out this thread, scroll to the bottom and see my post..
http://www.locostbuilders.co.uk/viewthread.php?tid=193791
It was that thread that made me ask! So I should talk to the motor factors, if not would an 8.8 M8 in fine be ok?
