Hi
Does anyone know of a UK supplier of 1/2" solid rod ends?
Like this
http://www.fkrodends.com/SPECIAL2PROD43.html
http://www.ebay.co.uk/usr/mcgillmotorsports?_trksid=p2047675.l2559
Visit the shows, reputable and reliable.
The rear swinging arms on my car are 1/2 and from Mcgills.
Berrisford have them
http://berrisford.co.uk/index.php/parts-components/rose-stud-ball-joints.html
Thanks again
Unfortunately none of them are solid.
Originally posted by rdodger
Thanks again
Make sure you get the very best you can can afford. A rod end failure could be disastrous!
I get mine from Ian dayson at force.not cheap but they are worth it imo
I had an off in my car, the so called expensive rod ends snapped and the McGill ones bent. My money will always be with him.
Of course only my opinion.
I suppose it depends where you got the 'expensive' ines from and what make they were!
I've no heard if many failures on the forces but I may be wrong.and of course tha cars are very very light
Thanks again
What do you mean by solid?
Have you tried bearingboys?
Can't help Rog, but what are they for?
[Edited on 4/8/15 by adithorp]
Hi Adi
I might have bought another GTM Libra
I want to use them to make the front top wishbones adjustable for camber while retaining the original Metro front upright/hub and top ball joint. They
currently have a ring on the end of the bone and camber is adjusted with shims between the tub and wishbone bracket.
I will need to taper them for a proper fit but using an adjuster sleeve I recon it will be the easiest way of making the camber easily adjustable.
