I am going to try and make my own front and rear wishbones, and was wondering if anyone else has made them themselves??
I am asking if anyone has any jigs I could borrow and return after use if possible, many thanks.ron.
I made mine years ago, all you need is a flat board some blocks of wood and screws.
Draw out what you want on the board, lay the tubes in place and use the wood to hold them in place.
For the bush tubes either leave long in the wooden jig and cut down once welded up to keep them true or insert a bit of scrap.
thanks mark.
